Hello everybody
I just installed Creo 9.0 on my computer. The installation didn't end well since I have a message saying the installation of virtual c++ redistribuables failed.
I could not find the reason why.
So I installed directly the visual ++ package, from Microsoft site, and it wen't well.
But as I try to launch Creo 9 parametrics 9.0.0.0, with the shortcut that appeared on my desktop, the hourglass briefly changes and return to its normal aspect, and nothing happens : Creo won't start.
Could anyone tell me if you see any solution, or even a log file to look into to understand what happens ?
Many thanks in advance for your help.
you can use Creo on computers with Intel/AMD processors. Is it your case?
Hi MartinHanak,
Unfortunlatey not. Running Snapdragon CPU...
Could this be the explanation of not starting without any message ?
JB
@JP_13013116 wrote:
Hi MartinHanak,
JB
yes, it is the explanation of not starting without any message. Snapdragon CPU is not supported. Please read following document.
https://www.3dpro.com.pl/files/others/creo11_hardware_notes.pdf
https://community.ptc.com/t5/System-Administration/Microsoft-Surface-Pro-3/m-p/416923
Some time back it looks like someone successfully ran it. I doubt it would be useful for anything but the simplest stuff.
