Creo Element Vs Creo 2 Regeneration Speed or Time
aselvaraj-2
2-Explorer
Since last week we are using Creo-2 and we felt that CREO-2 is taking more time for the Model regeneration. But if you regenerate same model in Cero element its taking less time compare with Cero-2.
I am using 12GB RAM, Processer = Intel(R) Xeon(R) CPU W3565 @3.20GHz.
Anybody aware of this why Cero-2 is taking more time than Cero Elements for model regeneration? Also suggest me If we have way to reduce regeneration time by manual settings.
Ananth
1 REPLY 1
if you are making a pattern which is not having a varied dimension and just simple pattern then you should go to--> pattern-->options tab-->regeneration option to "identical"
