Creo Parametric 1.0 - display problem
ptc-4528743
i need help with main creo window. I have this problem http://www.youtube.com/watch?v=PhdiXIgPDMQ
My PC:
ATI Radeon X1950Pro 512 MB
AMD Athlon X2 5600+ 2.8GHz
2048MB Ram
20Gb free hdd space
3000MB Virtual memory
Any solution? Thanks
The first thing I notice is the ATI Radeon card. PTC does not support Radeon. From ATI, they support most FirePro graphic cards. This may be the issue.
See this link for supported hardware http://www.ptc.com/WCMS/files/127428/en/creo1_hw_notes.pdf
Maybe you could make some adjustments in the control panel of your graphics card. Look for the control panel somewhere in the C: drive inside the ATI folder, if there is one. I use an Nvidia card and if I was to right-click on the desktop I would see Nvidida Control Panel in the short cut menu--maybe this works for ATI cards as well.
-Kevin
Hello!
Try to update your ATI video driver, here: http://support.amd.com/us/gpudownload/Pages/index.aspx
