Creo Toolkit startup error
rbadaracco
I tried to configure Ansys with Creo 2.0 previously, but the configuration failed. I tried many times with different settings until the toolkit startup error message window can't be closed. when i try closing it via windows task manager, creo exits too. In other words, I can't use Creo because the toolkit startup error message window won't let me. I uninstalled and reinstalled creo, but the problem persists every time I open Creo. I need some help, please.
6 REPLIES 6
Hi Rudy -
The image you attached showed that you had at least 8 occurrences (maybe 16 or more) of this error message:
Creo Toolkit registry file C:\Users\Rudy\WBPlugInPE162.dat
(from config.pro keyword PROTKDAT)
is a duplicate of C:\Users\Rudy\WBPlugInPE162.dat
While don't remember ever getting this error message myself, it seems obvious to me what it refers to: Your Creo configuration settings in one or more config.pro files has multiple instructions to load the toolkit registry file WBPlugInPE162.dat. The solution to this problem is to edit each config.pro file your installation has and disable the redundant protkdat lines that reference this file. Check your documentation if you don't know all the places where config.pro files might reside.
I can't imagine why this error would be repeated so many times. Could you really have that many redundant protkdat lines?
|+|  M a r k  |+|
bmüller
(To:rbadaracco)
have you found a solution?
We have the same Problem after installation of the 3Dconnexion space mouse driver.
Only one time complaining about duplicated protk.dat file from our Creo Management Tool.
If we delete the driver protk.dat in c:\ProgramData\PTC\Creo2\Plugins the error is gone. But we need to load the dll from this file.
Yes we could integrate the config values in our management tool, but we'd have to delete the driver .dat file after every driver update.
so I'm looking for a "clean" solution.
br Bernhard
bmüller
(To:bmüller)
It looks like, if the error message only shows up, if c:\ProgramData\PTC\Creo2\Plugins contains any subfolders...
BUT
Creo loads only *.dat files in subfolders from c:\ProgramData\PTC\Creo2\Plugins ...
Creo does not load *.dat files directly from c:\ProgramData\PTC\Creo2\Plugins
tested with Creo 2.0 M170
bmüller
(To:bmüller)
Problem is fixed at least in Creo 2.0 M220...
tfreed
3-Visitor
(To:bmüller)
Bernhard,
Did you simply delete c:\ProgramData\PTC\Creo2\Plugins contains any subfolders in order to remove the pop-up window with "duplicate" warning at startup?
Ted
bmüller
(To:tfreed)
Hi Ted,
yes, just delete all subfolders from c:\ProgramData\PTC\Creo2\Plugins.
But you will loose the config in the *.dat files. You could manually add the config lines to a .dat file delivered with Creo.
br Bernhard
