Default Option for Conflicts Screen Upon Save
ptc-5423342
Is there a config option that will set the defulat of the conflicts window to "OK" instead of "Cancel" upon a save?
The majority of the time, even with a blank model, the conflict "Mass properties are not calculated" appears for every model. Resolution requires two regenerations (one regeneration + save leads to "Model is not regenerated.").
mass_property_calculate is set to automatic. It looks like this has to be here in order for our drawings to update mass automatically.
I tried dm_checkout_on_the_fly continue. No change?
I also tried messing with dm_auto_conflict_resolution -- looks like this just skips the box altogether, which is not what I'm trying to do.
Any advice?
Thanks.
Jeroen
(To:ptc-5423342)
I'm not sure if this could solve your problem, but isn't it possible to create a mapkey/macro that regenerates your model (twice) and then save it?
This can replace your standard save-action.
