Hey all,
I wasn't able to search well enough to find any info on this.
Is it possible to set the default button to OK, vs Cancel on this dialog box?
7.0.4.0
A similar idea: https://community.ptc.com/t5/Creo-Parametric-Ideas/Make-OK-the-Default-when-you-delete/idi-p/467355
