Deploy CREO 10 using 7zip
cying
Prior to CREO 6, I can install a new release of CREO on my machine and create a 7zip archive.  Users can extract this archive and install this on their machine without using the software center or requiring local admin rights.  With the new releases now, you have to run the creoagent (creosvcs_64.exe) which requires admin rights.  PTC support stated that this is not a supported method, and not offering any workarounds.   I believe some folks are still using this method for their deployment.  Just curious how I can do this for our CREO 10 deployment and not have to rely on the software center.
Thank you all in advance!
Calvin
MartinHanak
(To:cying)
try simple test:
  • install Creo Parametric 10.0 on clean computer (I mean computer without any Creo installation)
  • zip installation
  • copy zip to another computer
  • unzip
  • run Creo
Note: In Creo 9.0 I had to add following lines at the end of parametric.psf file. Path corresponds with my installation.
ENV=CREO_AGENT_EXE_PATH=E:\PTC\Creo9_020\Creo\Agent\creoagent.exe
ENV=CREO_AGENT_LDP_LIST=E:\PTC\Creo9_020\Creo\Platform\9\manifests
Martin Hanák
5 REPLIES 5
MartinHanak
(To:cying)
try simple test:
  • zip installation
  • unzip
  • run Creo
Martin Hanák
cying
(To:MartinHanak)
Thanks, I will try this and update this post 🙂
cying
(To:cying)
I just realized that I never updated this post.  Thanks to all the suggestions, I am able to deploy CREO 10 without the need for local admin privileges 🙂
Calvin
dnordin
(To:cying)
It would be interesting to hear from PTC on what doesn't work using this method of deployment.  There are other tools/pre-requisites that are not installed when using this method.  The thumbnail viewer, 20XX vcredist_x64 & _x86, dot net framework, and java [and possibly device_api.dll].  What are all the components of the Creo Parametric installation that rely on these?
There are of course the obvious missing registry settings (file associations, uninstall commands, etc.), system environment variables, system start menu icons, and public desktop icons.
Another consideration before using this method is security/IT related.  Your company may require that software be "discoverable" on the PC's without having to do a full scan of the HD's on every machine.  This is typically done via the registry settings.
Dan N.
