Does it possible, in Creo 2.0, opening multiple files at once from a local folder?
ftoccaceli
7 REPLIES 7
unfortunatelly such functionality is not available. Also you can open 15 windows simultaneously, only.
MH
Martin Hanák
Thanks Martin,
as you know, isn't available even n Creo 3.0? Is this functionality planned to be introduced in future releases?
FT
I do not think that this functionality will be ever implemented.
Can you provide more details about your situation? Maybe I can suggest you how to solve it...
MH
Martin Hanák
No problem if I'm working connected to my Windchill server: through the workspace functionalities I can select multiple files and open them together in session (no more than 15) and this is ok.
But sometimes I need to work in stand-alone mode, and so multi-opening functionality isn't working. It's not a very impactful issue on my productivity, but in my CATIA V5 previous experience this functionality was useful.....so I'm just wondering if I can do the same thing (or similar) with Creo Parametric.
Hi Fabio,
As Martin mentioned, currently this functionality is not available. However you can submit a product Idea for this.
TomU
(To:Mahesh_Sharma)
There already is one.  Multiple file open functionality using selection ways as known in most operating systems
Until PTC decides to implement it, you could try the alternate methods here: Re: Batch saving and opening multiple files at once
JPM_LPE
2-Explorer
(To:TomU)
Anything else that can be done to escalate this? This is basic windows functionality in almost every other windows application. Seems a little insane that it isn't a feature in Creo yet.
