Drawing Setup
FrankSiano
Drawing Setup
Drawings have various block tolerances. How can I change them? The parameter &linear_0_000 appears in the frm but why sometimes .001 appears on the drawing but others have .031? What is the relationship and priority of config.pro vs dtl files, file path? I am confused how and where to control this.
Frank Your config.pro controls your model dimensions and your drawing.dtl controls how they are displayed on the drawing. Therefore if I set my model units to .00 then on my drawing they will display as .00. Your example was a little confusing that .001 does not equal a .031. If you would like a little more help on getting your drawing to output the correct dimensional display, I could give you some input on what settings you should be using. Regards Eric Mills
