We are using Creo 9.0
When we open "Cache Manager" in Creo, we select parts and try use function "Refresh", we are getting this error:
"Cannot get directory contents.
Failed to load library libpro2soacore.
Please ensure that the library is installed in path"
I am attaching config.pro file, couldn't find this library: "libpro2soacore"...
Our configuration is using config_9050 and config.sub to create config.pro
Hi @RP_10967543,
Thank you for your question.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
