Ok, just moved to Creo 2.0 and we've tried experimenting with installing Creo as a mapped network application. This is preferred when users lack administrative rights and you have limited IT staff. Great. Installs ok. Starts up, seems to work fine. There are number of little issues with the extra apps it tries to install on startup but those are minor. Ok, let's connect to PDMLink and start working. Wait where did server registry go???
Short summary - if you do not install the Creo Agent (Creo Platform), you cannot save the server registry. Lost when you shut down.
 www.utcaerospacesystems.comCONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
-----End Original Message-----
