First time installing Creo Parametric 5.0
KH_10254380
3-Newcomer
I am setting up a new laptop and need to install the Creo Parametric software on it for the first time. I would like someone to contact
me and help me through the process as there are no install files or documentation at this Company to use for the process.
I have downloaded the files that were shown for the install, MED-100WIN-CD-420_5-0-6-0_Win64
Not sure exactly what files are used to install Creo Parametric from this folder, can anyone help me with this install?
Dale_Rosema
(To:KH_10254380)
If you are new to the process, I would recommend contacting your VAR (Value Added Reseller). They can usually walk you through the process.
StephenW
(To:KH_10254380)
Dale_Rosema
(To:KH_10254380)
I reached out to Value Added Reseller and he walked me through the process.
Mainly download the correct version of software that you need and install it and enter your license or point it to the license server.
BenLoosli
(To:KH_10254380)
Setup.exe is the installer program
Do you have a license file?
