If you are new to the process, I would recommend contacting your VAR (Value Added Reseller). They can usually walk you through the process.
Best help I can give is https://www.ptc.com/en/support/creo-landing?source=community
I reached out to Value Added Reseller and he walked me through the process.
Mainly download the correct version of software that you need and install it and enter your license or point it to the license server.
Setup.exe is the installer program
Do you have a license file?
