Just curious....
Anyone heard of any issues running an NVIDIA GeForce 8800 GTX card with WF?
Windows XP
Desktop PC with plenty of speed and graphics power.
Well...it seems as thoughmy GeForce GTX has bit the dust! Now it's time to shop for a new one.
I am looking at the Quadro 2000D. Anyone have any experience or issues with this card for Wildfire?
Ihave a Quadro FX 580 on my new machine and it works fine on assemblies with millions of edges/surfaces. My default environment is "shaded with edges" with FastHLR enabled.
I've tested the 2k and 3k series of Quadro cards, and I've never measured an advantage of the more expensive cards over the 500 series of Quadro.
Given the relatively tinycost of workstation hardware vs. labor cost of the engineer's labor, you have to consider your budget.
If you are cost constrained, money is better spent on the fastest Core i7 (quad core) cpu. Xeon and 6-core are a total waste of money for ProEngineer
Well, it's times like these that I benefit from being a bit of a procrastinator when it comes to spending money.
Something just didn't sit well with meaccepting my graphic card was going belly up. I decided to do a little more research and found a small, one line descriptionby a user on a different forumfrom 2005 that sounded quite similar to my constant crashing.
He had an issue with the drawing module. As he moved the drawing around to work on different areas of the sheet, he would get bombed out of Pro repeatedly with funky blinking and "graphic wierdness" just before the crash. MIne happened to be in models and assemblies, especially when sketching. But....his solution, which ultimately was mine as well, was to remove any and all Microsoft Intellipoint, Intellitouch and Intellitype drivers. It seems there was a goofy conflict with Pro/E and the graphics. Since removing the drivers....crash free.
Thought I would share.
