Hole Table
ICAD_Support
Hole Table
I am using Creo Parametric Release 9.0 and Datecode9.0.1.0
Hello
I have created a block which has multiple simple hole.
but when I tried to get the depth of simple hole in hole table , I am not getting any parameters to add to hole table format.( But If i create a any standard other hole ,I can see multiple parameters BUT NOT FOR SIMPLE HOLE)
How can I add a depth of multiple simple hole in hole table with help of parameter's
Article - CS44121<< THIS ARTICLE ANSWERS MY UESTION BUT NOT ABLE TO REPLICATED THE PROCESS
1 REPLY 1
Create parameters (say depth1, depth2.....) for different depths.
Assign the parameters to the required depth.
Call the parameters in the hole table.
Personally, I do not like this method. I would rather have the hole table without depth, Group the different depths with a Phantom Line, take a section and show. Alternatively, use a parametric note with arrow that includes the depth.
Regards
Srinivasan Iyer
