Kindly give the brief explanations for how to create the protk.dat file for jlink applications and also porvide the config file for jlink applications ASAP.
I am moving this to Creo to give it the proper exposure.
Best,
Toby
Hello Toby,
Thanks for your reply.
When I will receive the final exposure.
Looks like already a protk.dat file is pointed by config.pro.
Thats why its shooting this error!!
Hello guys, you are rigth.
The PROTK.DAT file you have to creae for setting another functions. You have to set the filepath in the config.pro.
This filepath have to point to the PROTK.DAT that you had been created, for example, the following is to Enable Simscape Multibody Link Creo Plug-In.
Best regard 😄
JS
