How to determine Simulate licenses used by current session?
danderson
Trying to solve my lost license issue that happens when running a Creo Simulate static contact analysis. During the analysis run I'm losing the license multiple times during the run.
PTC ask us to install the license server on my workstation to eliminate a network cause. So I have a temporary license file (which should have all the modules I need) and the flex server installed on my machine. Problem is I'm not able to go into Simulate using this new license file.
I thought there used to be a way within Pro/e to see what License modules where being used for a model in session.
Can someone point me to another spot to get this information?
PTC Status and the license server logs are not providing me with the info I need.
on original license server
flex 3 license, MECSTRUCUI_ST
on temp license server
Don Anderson
0 REPLIES 0
