How can I disable the display of the conflict dialog that warns me that I am about to modify a drawing that is not yet checked out?
(See attached)
Config option? Windchill preference?
I know that there is a config.pro option to set "continue" as the default, but that doesn't stop the dialog from appearing.
I need this for a trail file, in which the drawing will be added to a workspace, then opened and modified in Pro/E, but it will not be checked back in. Normally, I would check-out the model, which would address this issue, but it might already be checked out.
Gerry
Oops. here's the dialog in case it wasn't clear what I was referring to.
Gerry
Thanks to all that replied, and special thanks to Mike, who informed me of the following undocumented config.pro option:
