How to modify pre-made notes?
bwyman
We have pre-made common notes that we place insert into our drawings using the NOTES > FILE.  The note files are stored on a common folder on our Windchill server.  Some of the notes need to be modifed/updated or new standard notes be added.  I can checkout note files through an external browser, but when I save the actual notes, it doesn't save in my workspace, it saves it to the text folder within the install directory.  So even though the note file is checked out, Windchill doesn't see it as modified, so it doesn't allow me to check-in anything.  There's also no "replace content" option when right clicking the note file in the Windchill browser.  I'm stumped.
Can anyone explain how to modify existing notes, or even how to add new notes into the Windchill server?
TomU
(To:bwyman)
Might want to read this: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS180044
I think you may have to reimport the saved file to the workspace (and snap it to the existing Windchill object).
2 REPLIES 2
TomU
(To:bwyman)
bwyman
(To:TomU)
This did exactly what I needed it to do.  Thank you!
