In wildfire 5.0,I can save a part in a assembly just choose select when saving,but in creo parametric,I could not find the select option when save in assembly mode.Is this option cancled in parametric?
From what I understand, and still cannot trust, is that any changed parts are saved by default when you save the assembly.
I tried several times, it really does work .
thanks.
Thank you for the confirmation.
