Saved search in 10.2 modify view
davehaigh
Ok so I setup a search and selected save and picked on advanced options.
I set the filename as a required attribute, and when it came to set table view, I picked New View
[cid:image004.jpg@01CFBC5F.DA1CA8A0]
After selecting columns, the order of those, and the sort order of the listing. I got my saved view.
Now I want to go back in and change the view.
How do I get back to it?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
________________________________
Pretty much only option is to select the saved search, then modify it, then
save it again as the same name.
davehaigh
(To:davehaigh)
Ok, I got an answer from PTC. It's not where I would have expected it to be.
Click the down arrow in the dropdown box that shows the view. Choose 'Customize...':
[cid:image001.png@01CFBC7F.FA550CA0]
Click the checkbox for the view you want to edit, and click the pencil icon (mousing over the pencil shows an 'edit' tooltag):
[cid:image002.png@01CFBC7F.FA550CA0]
From there you are in the same screens that you used to create the view, and can change the included columns and the sorting.
David Haigh
