We can use the Measure tool in Part environment and save the outcome as a feature that we can use for further processes (like in Relations). How could I do the same in the Assembly environment?
I tried to replicate it in the assembly environment by saving the measured analysis using the Make feature option but the saved feature is not there in the model tree.
I hope I am clear with my question, if not please point out. I'll try to explain it further.
Regards
Charles Bronson A
I don't have any problem with save my analysis as a parameter in assembly, Creo 2.0 M240
Regards
Leonid
in Creo Parametric 4.0 M030 I am able to create analysis feature in Part mode and also in Assembly mode. What Creo version do you use ?
Hi Martin
I have been using Creo 2.0 M060. I can do assembly analsyis but I couldn't save it as a parameter.
Regards
Charles
Regards
Leonid
Hi
I changed the tree filter option to include features in the model tree and with that all my save analysis were displayed as features. This was a silly mistake on my part. Thanks for the help.
Regards
Charles
in Creo Parametric 2.0 M070, in Assembly mode, I can measure the distance between two parallel planar faces and save analysis as feature. The feature contains parameter named DISTANCE.
Hi
I changed the tree filter option and it worked fine. This was a silly mistake on my part. Thanks for the help.
Regards
Charles
