How to solve the problem of "unknown licensing error 26"
ptc-6616838
I downloaded the creo 2.0 student edition and I installed it, but when I try to open the "Thermal" and the "Structure", there is a problem of "unknown licensing error 26",and if I click "OK", it wil be closed. How can I solve that problem? Please!!!
1 REPLY 1
I guess that you are trying to run STANDALONE version of Thermal/Structure. I am almost sure it is not possible. You can run analysis from Creo Parametric, only.
For example:
  • open a part
  • activate Applications tab
  • click Simulate button in ribbon ... now you are in Simulate environment
Martin Hanak
Martin Hanák
