How to transfer only specific required mapkey from one config.pro to other config.pro ?
VinitKadamITT
How to transfer only specific required mapkey from one config.pro to other config.pro, without affecting other mapkeys or other configuration option.
Requirement is the other configuration options are different for first config.pro file & second config.pro file.
Means replacing the config.pro solution is not required.
StephenW
(To:VinitKadamITT)
Open the config.pro with a text editor (like notepad). Find the mapkey. Copy all the lines of the mapkey. Paste the mapkey in to the other config.pro using a text editor.
Thanks Stephen.
After finding the mapkey in config.pro using text editor, How to find the last line up to which we have to copy for perticular mapkey?
Vinit,
below you can find some examples...
If the mapkey has n lines (n>1) then:
  • lines 1..n-1 end with backslash character
  • lines 2...n start with mapkey(continued)
!*** close window ... 3 lines
mapkey ww ~ Select `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Activate `main_dlg_cur` `main_dlg_cur`;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdWinCloseGroup`;
!*** erase not displayed ... 2 lines
mapkey ee ~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdModelEraseNotDisp` ;~ Activate `file_erase_nd` `ok_pb`;
!*** close window, erase not displayed ... 1 line
mapkey qq %ww;%ee
Martin Hanak
Martin Hanák
