hello
In my system the same name of two folders created at the same location. I don't know how this happened. after this, I set the working directory in the same folder and worked on the project after that do not show the model in this working directory and then rename this folder problem solved
If you have search paths in any config file, it could be finding the part.
If you have already opened the part in a different folder and didn't erase memory before changing working directories.
If the part is a family table instance, the only file in the folder will be the generic model. One way to tell if it is a family table part is to open the part by itself and look in the bottom LH corner, if it says "instance", then it is part of a family table.
With Regards,
Chandan Kumar
Mob.+91-9708668072
It seems there is no image
you can either copy and paste and image in to the body of the post.
or
you can attach a file using the insert photo icon
With Regards,
Chandan Kumar
Mob.+91-9708668072
Are you opening at STEP file? A .stp file can be an assembly, and when opened in creo, will generate part files/assy's for the models from the import.
Especially when the subcomponents are named like this:
With Regards,
Chandan Kumar
Mob.+91-9708668072
Could you post what the problem was specifically and how you fixed it? This would likely be helpful to others in the future.
hello
Hi @chandan
You may accept your reply to post as accepted solution to close the conversation.
Mahesh
