I am looking to replace our Workstation, any recommendations on a configuration / manufacturer? We have assemblies of 3000+ components. We currently have T5600, 24 gig ram, Quadro 4000. They just do not cut it on our regenerations. Some of it is "bad" mod
mpollagi
2-Explorer
regenerations. Some of it is "bad" models I am sure.
6 REPLIES 6
Your current config looks pretty solid... I'd have to say that if you had dual processors and SSD's you'd see a real performance increase. Graphics cards are not going to help regen times.
mpollagi
2-Explorer
(To:mpollagi)
Pete, "I'd have to say that if you had dual processors and SSD's you'd see a real performance increase." I did not think Creo utilized more than 1 processor, also when doing a regeneration what envolvment does the hard drive have? Thanks
TomU
(To:mpollagi)
Mark Pollagi‌,
You are correct.  The vast majority of the time Creo will only use a singe core of one processor.  This is why clock speed matters so much.  I highly recommend using an overclocked machine if at all possible.  We use machines from Gruman Creations and have been very happy with them.
mpollagi
2-Explorer
(To:TomU)
Tom, Will these be PTC certified, or don't you worry about that? What is your typical configuration? Thanks
TomU
(To:mpollagi)
No, not certified.  For us that doesn't matter.  To be certified you have to be willing to give PTC a free computer and I think even pay them to certify it.  For a small company like Gruman, that just isn't possible.  PTC technical support will provide support for non-certified hardware.  From CS221822:
PTC Technical Support will provide assistance to customers using hardware that is neither certified nor supported
Here is PTC's Platform Support page:  http://support.ptc.com/partners/hardware/current/status.htm
davehaigh
(To:mpollagi)
Dell Precision Workstations come in three box sizes. 3000, 5000, & the 7000 series (3000 used to be 1700)
The fastest processors you can get are in the 3000 series. As you step up in box size what you get is more parallel cores, but slower speeds. Not a good trade off for Creo.
Dell discontinued the 1700 line a few months back so now all you can buy in the small box is the 3620.
We bought some, I was skeptical because the single threaded performance numbers for the CPU indicated to me they would not be as fast as our previous T1700's but they are faster. OCUS Benchmark results below: (These are the two fastest major name brand machines on the site)
Precision Tower 3620 = I haven't uploaded these results but this would be #14 on the benchmark site.
Intel(R) Xeon(R) CPU E3-1270 v5 @ 3.60GHz = Single threaded score 2215
Total Physical Memory:     65,462 MB
NVIDIA Quadro K2200
OS Name:                   Microsoft Windows 7 Professional
OS Version:                6.1.7601 Service Pack 1 Build 7601
64_Bit
Creo 2.0-M190
Total    = 986 seconds
CPU Related tasks (CP)  = 704 seconds
Graphics Relatsed tasks (GR) = 269 seconds
DISK related tasks (DI)  = 157 seconds
Our previous T1700 had this result. Both machines have SSD hard drives:
Precision T1700  = This is # 20 on the benchmark site.
Intel(R) Xeon(R) CPU E3-1271 v3 @ 3.60GHz = Single threaded score 2315
Total Physical Memory:     32,707 MB
NVIDIA Quadro K4000
OS Name:                   Microsoft Windows 7 Enterprise
64_Bit
Creo 2.0-M120
Total    = 1177 seconds = 19 minutes 37 seconds
CPU Related tasks (CP)  = 807 seconds
Graphics Relatsed tasks (GR) = 356 seconds
DISK related tasks (DI)  = 177 seconds
