Installation Problem Creo 1.0
ptc-4936073
Hi everybody !
It's now two days that i search all the way to find a solution to install Creo 1.0. I want to install the school version i'm following the process that the help gives you. The trouble is that when i'm downloading Creo 1.0 License utility i can't make it run my computer show me two possibility :
The installation is made correctly (if i press it nothings happen)
Make a reinstallation (if i press it well nothing happens too !)
I'm getting a bit crazy because then i can't create my PTC account and then i can't use it,
I need it for my school project so if you can give me some advice i would be grateful !
Have a good day and see you soon !
Magdaléna
hi,
Might wanna try poking this section of the forums http://communities.ptc.com/community/academic-program/support
~Jakub
okay thank's
