Hi, all,
I have this weird message when I open an assy:
Line 5 Feature GROOVE id 67 of Model 120330:Invalid left side of assignment
Does anyone knows what that means? Beside that I get another one:
Could not read from Model Tree config file $GRI_ENG_CFG/tree.cfg.
which also I don't know what it means.
Thank you,
Nic.
Can you post some more of the PRO/PROGRAM around that feature?
And the relevant RELATIONS also?
Feature in Pro/Program:
IF BN1 != "No"
IF BN2 == "180 Groove"
ADD FEATURE (initial number 10)
INTERNAL FEATURE ID 67
GROUP HEAD
NO. ELEMENT NAME INFO
1 Name Defined
2 Features Defined
3 Construction Defined
NAME = GROOVE
MEMBER OF A GROUP, NAME = GROOVE
LEADING FEATURE OF THE GROUP: ID = 67
LAST FEATURE OF THE GROUP: ID = 34
END ADD
ADD FEATURE (initial number 11)
INTERNAL FEATURE ID 34
FEATURE WAS CREATED IN ASSEMBLY 120330_TEMPLATE_ASM
PARENTS = 1(#1) 3(#2) 32(#9) 33(#8) 5(#3)
CUT: Revolve
1 Feature Name Defined
2 Extrude Feat type Solid
3 Material Remove
4 Section Defined
4.1 Setup Plane Defined
4.1.1 Sketching Plane PL_AXY:F3(DATUM PLANE) ID=6
4.1.2 View Direction Side 1
4.1.3 Orientation Top
4.1.4 Reference PL_AYZ:F1(DATUM PLANE) ID=2
4.2 Sketch Defined
5 Feature Form Solid
6 Material Side Side Two
7 Revolve Axis Defined
8 Revolve Axis Option Internal Centerline
9 Direction Side 2
10 Angle Defined
10.1 Side One Defined
10.1.1 Side One Angle None
10.2 Side Two Defined
10.2.1 Side Two Angle To Reference
10.2.2 Reference PL_XY:F3(DATUM PLANE):120330_TEMPLATE_LINING ID=
10.2.3 Rev Limit Side Two
11 Intersect Parts Defined
FEATURE BELONGS TO LOCAL GROUP GROOVE
SECTION NAME = S2D0004
FEATURE'S DIMENSIONS:
OIL_GROOVE_HEIGHT = (Displayed:) 1.99 General_Dims (2.09 1.89)
( Stored:) 1.9945 ( 0.1, -0.1 )
HP_AUX = (Displayed:) 53.24 General_Dims (53.54 52.94)()
( Stored:) 53.24 ( 0.3, -0.3 )
d248 = (Displayed:) 33 +/-1 X 45 Deg
( Stored:) 32.8 ( 0.01, -0.01 )
BACK_OF_GROOVE = (Displayed:) 0.9
( Stored:) 0.9 ( 0.25, -0.25 )
d257 = (Displayed:) 0.90 (1.0 0.8)
( Stored:) 0.9 ( 0.1, -0.1 )
d259 = (Displayed:) 2.79 General_Dims (2.89 2.69)
( Stored:) 2.79 ( 0.1, -0.1 )
GROOVE_RADIUS = (Displayed:) 1.00 General_Dims (1.1 0.9)R
( Stored:) 1.0 ( 0.1, -0.1 )
GROOVE_ANGLE = (Displayed:) 32.80 (33.3 32.3)
( Stored:) 32.8 ( 0.5, -0.5 )
GROOVE_WIDTH_BOTTOM = (Displayed:) 2.79 General_Dims (2.89 2.69)
END ADD
END IF
END IF
Relations in pro/Program:
/*GROOVE>>>START
GROOVE_RADIUS=BP:1
GROOVE_ANGLE=BR1:1
BACK_OF_GROOVE=CU1
GROOVE_WIDTH_BOTTOM=CV1
CU3 = CU1-CU2
CU4 = CU1+CU2
CV3 = CV1-CV2
CV4 = CV1+CV2
/*GROOVE>>>FINISH
/*PARTIAL GROOVE AT JOINTS>>>START
D515 = 90 - BS1
JOINT_PARTIALGROOVE_RADIUS = BP
JOINT_PARTIALGROOVE_BOTTOMWIDTH = CV1
JOINT_PARTIALGROOVE_OPENANGLE = BR1
JOINT_PARTIALGROOVE_BACK = CU1
JOINT_PARTIALGROOVE_LENGTH = BS1
/*PARTIAL GROOVE AT JOINTS>>>FINISH
/*PARTIAL GROOVE>>>START
D517 = 180 - CW1
IF CW1 > 0
D639 = CW1
ENDIF
IF CW1 < 0
D641 = -CW1
ENDIF
D630 = BS1/2
D634 = BS1/2
BACK_OF_PARTIAL_GROOVE = CU1
PARTIAL_GROOVE_LENGTH = BS1
PARTIAL_GROOVE_RADIUS = BP
PARTIAL_GROOVE_OPENING_ANGLE = BR1
PARTIAL_GROOVE_WIDTH_BOTTOM = CV1
/*PARTIAL GROOVE>>>FINISH
(probably the first block of relations has something to do with the error)
Thank you,
Nic.
Look for the relations for the feature - these are not the part relations.
the feature is created in the assembly.
Off topic: what does the "$" means in a relation? Example:
/*>>>>>>>>>>>>>>>>>>>>>POSITION HOLE_1
$CELL_DA=-OIL_HOLE1_ANGLE
The $ sign is needed to assign a negative value.
Relations can be created at the part level, the feature level, and the sketcher level, among others.
I think your failed relation is at the feature level.
See About Adding Relations Creo Parametric Help Center
Just a tip here: We create all our relations at PART or ASSEMBLY level. Relations "hidden" in features or sketches are hard to find.
MH
I guess there was a feature name called GROOVE that is now deleted or suppressed.
and "Line 5" is referred to what list?
Did you look for the feature relation?
Yes. Here there are the one in the Relations block:
/*GROOVE>>>START
GROOVE_RADIUS=BP:3
GROOVE_ANGLE=BR1:3
BACK_OF_GROOVE=CU1
CU3 = CU1-CU2
CU4 = CU1+CU2
CV3 = CV1-CV2
CV4 = CV1+CV2
/*GROOVE>>>FINISH
And what "Line 5" refers to? Should be a list of relations where the 5th line doesn't work right
