Invalid left side of assignment message in Line 5 Feature NAME id 6 of Model ASSY
  • May 5, 2017
  • 4 replies
  • 8733 views
Hi, all,
I have this weird message when I open an assy:
Line 5 Feature GROOVE id 67 of Model 120330:Invalid left side of assignment
Does anyone knows what that means? Beside that I get another one:
Could not read from Model Tree config file $GRI_ENG_CFG/tree.cfg.
which also I don't know what it means.
Thank you,
Nic.
HamsterNL
18-Opal
May 5, 2017
Can you post some more of the PRO/PROGRAM around that feature?
And the relevant RELATIONS also?
Feature in Pro/Program:
IF BN1 != "No"
     IF BN2 == "180 Groove"
         ADD FEATURE (initial number 10)
         INTERNAL FEATURE ID  67
GROUP HEAD
  NO.   ELEMENT NAME  INFO
   1    Name          Defined
   2    Features      Defined
   3    Construction  Defined
         NAME = GROOVE
         MEMBER OF A GROUP, NAME = GROOVE
          LEADING FEATURE OF THE GROUP: ID = 67
          LAST FEATURE OF THE GROUP: ID = 34
         END ADD
         ADD FEATURE (initial number 11)
         INTERNAL FEATURE ID  34
         FEATURE WAS CREATED IN ASSEMBLY 120330_TEMPLATE_ASM
         PARENTS = 1(#1) 3(#2) 32(#9) 33(#8) 5(#3)
CUT: Revolve
   1       Feature Name         Defined
   2       Extrude Feat type    Solid
   3       Material             Remove
   4       Section              Defined
   4.1     Setup Plane          Defined
   4.1.1   Sketching Plane      PL_AXY:F3(DATUM PLANE) ID=6
   4.1.2   View Direction       Side 1
   4.1.3   Orientation          Top
   4.1.4   Reference            PL_AYZ:F1(DATUM PLANE) ID=2
   4.2     Sketch               Defined
   5       Feature Form         Solid
   6       Material Side        Side Two
   7       Revolve Axis         Defined
   8       Revolve Axis Option  Internal Centerline
   9       Direction            Side 2
   10      Angle                Defined
   10.1    Side One             Defined
   10.1.1  Side One Angle       None
   10.2    Side Two             Defined
   10.2.1  Side Two Angle       To Reference
   10.2.2  Reference            PL_XY:F3(DATUM PLANE):120330_TEMPLATE_LINING ID=
   10.2.3  Rev Limit            Side Two
   11      Intersect Parts      Defined
         FEATURE BELONGS TO LOCAL GROUP GROOVE
         SECTION NAME = S2D0004
         FEATURE'S DIMENSIONS:
         OIL_GROOVE_HEIGHT = (Displayed:) 1.99 General_Dims (2.09 1.89)
                             (   Stored:) 1.9945 ( 0.1, -0.1 )
         HP_AUX = (Displayed:) 53.24 General_Dims (53.54 52.94)()
                  (   Stored:) 53.24 ( 0.3, -0.3 )
         d248 = (Displayed:) 33 +/-1 X 45 Deg
                (   Stored:) 32.8 ( 0.01, -0.01 )
         BACK_OF_GROOVE = (Displayed:) 0.9
                          (   Stored:) 0.9 ( 0.25, -0.25 )
         d257 = (Displayed:) 0.90 (1.0 0.8)
                (   Stored:) 0.9 ( 0.1, -0.1 )
         d259 = (Displayed:) 2.79 General_Dims (2.89 2.69)
                (   Stored:) 2.79 ( 0.1, -0.1 )
         GROOVE_RADIUS = (Displayed:) 1.00 General_Dims (1.1 0.9)R
                         (   Stored:) 1.0 ( 0.1, -0.1 )
         GROOVE_ANGLE = (Displayed:) 32.80 (33.3 32.3)
                        (   Stored:) 32.8 ( 0.5, -0.5 )
         GROOVE_WIDTH_BOTTOM = (Displayed:) 2.79 General_Dims (2.89 2.69)
         END ADD
     END IF
END IF
Relations in pro/Program:
/*GROOVE>>>START
GROOVE_RADIUS=BP:1
GROOVE_ANGLE=BR1:1
BACK_OF_GROOVE=CU1
GROOVE_WIDTH_BOTTOM=CV1
CU3 = CU1-CU2
CU4 = CU1+CU2
CV3 = CV1-CV2
CV4 = CV1+CV2
/*GROOVE>>>FINISH
/*PARTIAL GROOVE AT JOINTS>>>START
D515 = 90 - BS1
JOINT_PARTIALGROOVE_RADIUS = BP
JOINT_PARTIALGROOVE_BOTTOMWIDTH = CV1
JOINT_PARTIALGROOVE_OPENANGLE = BR1
JOINT_PARTIALGROOVE_BACK = CU1
JOINT_PARTIALGROOVE_LENGTH = BS1
/*PARTIAL GROOVE AT JOINTS>>>FINISH
/*PARTIAL GROOVE>>>START
D517 = 180 - CW1
IF CW1 > 0
D639 = CW1
ENDIF
IF CW1 < 0
D641 = -CW1
ENDIF
D630 = BS1/2
D634 = BS1/2
BACK_OF_PARTIAL_GROOVE = CU1
PARTIAL_GROOVE_LENGTH = BS1
PARTIAL_GROOVE_RADIUS = BP
PARTIAL_GROOVE_OPENING_ANGLE = BR1
PARTIAL_GROOVE_WIDTH_BOTTOM = CV1
/*PARTIAL GROOVE>>>FINISH
(probably the first block of relations has something to do with the error)
Thank you,
Nic.
Look for the relations for the feature - these are not the part relations.
  • probably relation problem, I can't give you more precise information without having the model
  • $GRI_ENG_CFG is call out of environment variable named GRI_ENG_CFG, which does not exist
MH
I guess there was a feature name called GROOVE that is now deleted or suppressed.
and "Line 5" is referred to what list?
Did you look for the feature relation?
Yes. Here there are the one in the Relations block:
/*GROOVE>>>START
GROOVE_RADIUS=BP:3
GROOVE_ANGLE=BR1:3
BACK_OF_GROOVE=CU1
CU3 = CU1-CU2
CU4 = CU1+CU2
CV3 = CV1-CV2
CV4 = CV1+CV2
/*GROOVE>>>FINISH
And what "Line 5" refers to? Should be a list of relations where the 5th line doesn't work right
