Is there a config setting to make placement constraint Coincident the default?
Doug_Fowler
2-Explorer
Is there a config setting to make Placement constraint Coincident the default as Normal or distance seems to be the current defaults? Taking time to drag a part and orient it prior to placement in a large assembly is not efficient. Most of my assembly constraints tend to be Coincident and rarely (never) Normal.
TomU
(To:Doug_Fowler)
comp_angle_offset_eps 91
comp_normal_offset_eps -1
auto_constr_always_use_offset never
See: Re: Assembly constraints
I found the answer by trying to submit a case for this question, which in retrospect should have been my first step. Turns out a similar case was previously submitted; CS198652. Set the config.pro options:
  • comp_angle_offset_eps to 91
  • comp_normal_offset_eps to -1
  • auto_constr_always_use_offset to never
It had been years since I last submitted a case and so I was pleasantly surprised to see the case submittal process has sufficient Artificial Intelligence (AI) search algorithms to bring up possible answers before a new case has to be submitted.
BTW,
Thanks, Tom.
gkoch
(To:Doug_Fowler)
Hello Douglas,
thank you for your feedback!
At PTC Technical Support we have in fact invested some efforts (and money!) during the recent years to enable better self-help.
Comments like yours make us proud and confirm we are going the right direction.
But our recommended "order" of steps would be:
This usually increases the chance to get the answer as fast as possible.
(and of course for questions regarding how to use the functionality, the PTC/Help should come first or maybe at least second)
Gunter
