I am using Creo Parametric Release 4.0 and DatecodeM140
In drawing sheet while creating linear dimension with reference of edge and bend axis dimension created but getting PRO_TK_INVALID_MATRIX error while using this api "PROANNOTATIONSHOW".
when the drawing is active that time there is no error but when we open the drawing programmatically then getting error
Here are the errors that I faced
PROANNOTATIONSHOW - PRO_TK_INVALID_MATRIX
Similar issue earlier - "Proannotationshow api showing status us pro_tk_invalid_matrix": https://community.ptc.com/t5/Customization/Proannotationshow-api-showing-status-us-pro-tk-invalid-matrix/m-p/914698
