new quick access function in file open dialogue box pins selection by type
I am using Creo Parametric Release 10.0 and Datecode10.0.0.0
After opening an item using "file open" dialogue box and "type" pulldown to filter by type (e.g. drw, prt, asm), the new Creo 10 "quick access" bar within the "file open" dialogue box automatically "pins" the type selection so that the same file type filter is still active the next time the user uses "file open". This presents a problem when a drawing is being worked on. Previously, Ctrl-O ("file open" shortcut)/Enter keystroke sequence was a very rapid way to open the active model in the drawing, since the active model is the default value inserted by Creo in the "File Name" field. However since file type is now pinned to previous selection (e.g. drawing), "Invalid Extension" error occurs upon Ctrl-O/Enter keystroke sequence and the user must now use an additional mouse click to "deselect" the pinned selection before pressing enter. The user should have the option to pin or not to pin the "type" selection in order to reduce mouse clicks in the workflow.
