I'm wondering if it's possible to extract all mapkeys from a config.pro file and transform it to csv or xls file.
In order to sort all of them (mapkeys keys and descriptions).
I would like to clean all my config.pro files and test.
Thanks !
Sounds like the "Mapkey Manager.xlsm" from this post might be similar to what you're looking for - https://community.ptc.com/t5/System-Administration/Managing-Many-Mapkeys/td-p/449765.
Always be wary of VBA files from the internet though. You can preview the code before enabling the VBA macros using ALT-F11.
It is certainly possible to do this with some programming. Why not just use one of the better text editors such as Notepad++ and manipulate the text format directly. There are some customizations for Creo available for Notepad++ which may be helpful to you.
https://notepad-plus-plus.org/
The configuration files are just plain text files. Any text editor can open the files and you can manipulate the information from there.
what about this ... please replay video
Thank you, nice and simple solution !
I can't find how to enable Macro, right now.
But I will look more in detail.
https://www.youtube.com/watch?v=joaC7QyRAPs
