Hello ptc community,
Is it possible to get an overview to loading cycles.
For Example a big assembly should get loaded to Creo, my point of view at Creo 4.0 is, that i only can watch at the taskmanager that the file gets loaded (throgh looking at the RAM load, CPU and GPU have not much to do at that state).
Also between loading utilizations the programm is kind of locked until the File is completly available.
I think a progress bar maybe with a percentage value would give an overview of the task.
For program commands (for example: clusters) there is already a progress bar that shows the final calculated geometry that has been clustered.
Yours sincerely
Alexander
There are some performance monitors other than task manager that lets you look at other system performance aspects of your system.
https://www.ptc.com/en/support/article/CS199298 Possibly the performance advisor is what you are looking for
I think this link is the sales sheet for performance advisor.
https://ptc-p-001.sitecorecontenthub.cloud/api/public/content/fd2a3f379c764447972b33f7068850b5
Hi @Alex_R730,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
What could be interesting for users is like the taskspeeds between the versions of Creo.
(Kind of simularity to the benchmarks between older and newer graphics card model benches on videogames or more detailed on the game engines / programmsoftware as I know)
Differences between other CAD programs are the user interface so some CADs are minimalistic, some as Creo have a bit more combined Symbols with Text. That is a base of userinterfaces, also some programs have the option to customize the user interface or in a another way to adapt, add, the standard HUD.
