Hi there, normaly i always have side icons in the main menu. e.g. in the menu File> Save there is a small disc at the side. I do not see those icons any more in any of the main menu's. Is there for example a configuration that i can use or could it be du to a start up batch file that i am using now to set my environment? Regards, Ferry
