Manikin Vision Window Render
DC_10764582
2-Explorer
I am using Creo Parametric Release 7.0 and Datecode7.0.6.0
Trying to save rendered image with vision window. How do I do that?
8 REPLIES 8
make printscreen ?
Martin Hanák
That's an option, but there should be a way to export the image at a better quality than printscreen.
StephenW
(To:DC_10764582)
How about File-Save As and then select file type Tiff or png or ??
After it renders, you can right click and save image, but the image it saves is not the rendered image.
Hi @DC_10764582 ,
I would be great if you can share the detailed steps of review this issue.
Thanks.
Hi @DC_10764582
I tried reproducing the issue however it is not reproducible with generic steps. It would be great if you can share the detailed steps to reproduce the issue.
Thanks.
I don't know the steps. That's what I need to know. How to save a rendered image through Manikin Vision Window?
Hi @DC_10764582
RMB > Save Image is one to save rendered vision window and I tested that, it is working well for me.
Thanks.
