when installing Creo 9.0 you have to use following information:
K-12 students can use Product code BE900908EDSTUDENTEDK12
University students can use Product code BK900908EDSTUDENTEDUNI
https://apps.ptc.com/schools/references/install_creo9_unistudent_standard.pdf
https://apps.ptc.com/schools/references/install_creo9_schools_standard.pdf
You may need to obtain a new license file for Creo 9.
Also, the student edition uses a modified file format so a normal download of Creo 9 will not work.
is there a new code for 2024? as i am struggling right now
Creo 9.0 product codes remain the same.
Creo 10.0:
https://apps.ptc.com/schools/references/install_creo10_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo10_unistudent_standard.pdf
