Mapkeys.pro - custom administrator path
PL_10543256
In Creo 11 there is a new mapkeys.pro file, which is split from config.pro file. How to set up an alternative folder for mapkeys.pro file. Under Help Center there is an information which says, there is a possibility to set customized path?
Dale_Rosema
(To:PL_10543256)
Hi @PL_10543256,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
