Mass Properties and Family Tables
Robert-Altman
Is there a trick to get the Mass Properties to refresh in family tables.
The steps I have taken are:
1. Create a solid part BOX 12x12x12
2. Compute current mass properties
3. Regen
4. Add relation --> surface=mp_surf_area(")
5. Save
6. Create family table --> add column --> add "SURFACE" parameter and the three dimensions
7. Insert a few new instances and modify some of the dimensions
8. Verify
9. The surface area displays 864.0 for all the instance even though the dimensions are different.
[cid:image002.png@01CF3A03.AD7F2EA0]
10. Regen
11. Check the family table and the surface area values are still the same.
12. The only way I seem to be able to get it to update is to make a change to the file that requires the family table to be verified.
I also have a config.pro setting --> mass_property_calculate automatic
Is there something I'm missing?
Thanks in advance,
[cid:012445618@15012007-1FE4]
BenLoosli
(To:Robert-Altman)
The verify process is doing the 'regen' on the FT members, so the update to the surface would not take place until that was done. I had the same issue with FT member weights in WF2.
I've always had to resort to the following:
After making dimensional modifications but before verifying the table make the following pick:
Tools > Show System Mass Properties
Then perform the Verify step with the properties showing.
[cid:image003.jpg@01CF3C26.756FD1C0]
Mike Foster
ATK
Thanks for the reply Mike,
Turns out that the key element that I was missing was setting the "Relations" under "Post Regeneration"
[cid:image004.png@01CF3D00.4CFCBD40]
