We just updated to Creo Parametric 3.0 (M070). We have noticed that the middle-mouse-button (MMB) no longer completes features as it did in Creo Parametric 2.0. Is anyone else seeing this? Does anyone know how to fix it? We have a call into PTC, but we are not getting helpful answers yet.
Thanks guys for the replies. We actually found the problem was related to a trail file we run to open Creo. We updated the trail file using Creo 3 and the problem went away.
if you are on Windows 10, read How to make scroll wheel zoom work in Windows 10 with Creo Parametric
MH
Perhaps you had feature_create_auto_ok set to yes in Creo 2 and it did not get set in Creo 3? I'm not certain this controls that behavior, but it's worth looking into.
