I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
1. How to customize the operation of replacing the drawing frame when saving the drawing by default? Or in the 3D model, customize the operation of adding parameters when saving the model!
2. In the 3D model, can it be defined to automatically verify the parameters when saving? If the specified parameters do not exist, it cannot be saved!
3. Under the "File" option operation, can the "New" operation of OTB be removed!
Contact number: 15895986870 Email: 15895986870@163.com
Translated text from Simplified Chinese to English using google translate.
Title - 模型和图纸校验
Body - 1、如何操作,能够在默认操作保存图纸时,能够自定义执行一次替换图框的操作?或者在三维模型中,保存模型时,自定义执行一次添加参数的操作!
2、在三维模型中,能否定义在保存时,自动校验参数,不存在指定参数时,无法保存!
3、“文件”选项操作下,能否移除OTB的“新建”操作!
联系电话:15895986870 邮箱:15895986870@163.com
- By Community Moderation Team
Hi @EY_8056987,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
