Hi all
Just trialling ModelCheck to add some missing parameters to a bunch of files and I am trying to do it using batch mode (not distributed batch mode) with a txt file listing the models to be updated.
I can more or less get what I want it to do except I have to put my part and assembly files into the bin folder of where I have installed Creo. I would like it to run in a folder of my choosing but I can't seem to do it. I have tried pointing the modelcheck.bat file to a specific desktop icon with the 'Start in' field defined correctly and it does start Creo ok as I can see xtop.exe appearing in the task manager - it is also loading a config.pro file with the option File_open_default_folder set to 'working_directory'. But after a few seconds I get a report back to say it can't retrieve any of the models.
If I move the model files into the bin folder then it works fine.
What am I doing wrong?
Neal
