Modifying config.pro for Absolute Accuracy
sdensberger
I'd like to modify my config.pro file so that I don't have to go through File>Prepare>Model Properties and change the Accuracy from Relative to Absolute. I've already modified the config.pro file for enabling Absolute Accuracy (enable_absolute_accuracy = yes) and for the default value (default_abs_accuracy = 1e-6), but I can't find a parameter for changing the default from Relative to Absolute. Is there a parameter for this, or am I stuck going through the manual repetition each time I create a new part?
Inoram
(To:sdensberger)
I do this with my start part.
or part template, whatever you want to call it.
assembly also.
As far as I know there is no config option to have new files start with absolute accuracy. Like Matt we do this with our file templates.
This may be a good thing for PTC to add to Creo 3.0.
