Notepad++ User Defined Language files for Creo Parametric and Pro/ENGINEER
DomenicLaritz
The ZIP archive contains Notepad++ UDL files for config.pro and drawing setup (dtl) options.
I've created them for following CAD versions:
  • WF4 (= Pro/E Wildfire 4)
  • CEP5 (= Creo Elements/Pro 5, formerly Pro/E Wildfire 5)
  • CP2 (= Creo Parametric 2)
  • CP3 (= Creo Parametric 3)
  • CP4 (= Creo Parametric 4)
Basis for the options were the lists of Olaf Corten (thanks for them) http://proesite.com/UTIL/view_config.html and http://proesite.com/UTIL/view_setup.html.
General config.pro options get shown dark blue and bold.
Hidden config.pro options get shown in a lighter blue, bold and italic.
Comments get shown brown and can be folded, if they consist of several lines.
Drawing setup (dtl) options alse get shown dark blue and bold.
To add a UDL file to Notepad++, choose "Language" and then "Define your language" in the menu.
In the dialog which is opened then, choose the button "Import" and then the appropriate XML file.
https://github.com/DonChunior/Creo-Configuration-Files
64 REPLIES 64
I've released the new version 10.4.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 10.0.8.0 and Creo Parametric 11.0.4.0.
Thanks to @ocorten-2 for providing the lists with the settings on his website https://creosite.com/.
I've released the new version 11.0.0 of the Notepad++ UDL files on GitHub:
  • Added UDL files for Creo Parametric 12.4.0.0.
  • Moved UDL file from ModelCHECK to separate directory for better findability.
I've released the new version 11.1.0 of the Notepad++ UDL files on GitHub:
  • UDL files for dark theme added.
I've released the new version 11.2.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 10.0.9.0.
I've released the new version 11.3.0 of the Notepad++ UDL files on GitHub:
  • Updated UDL files for Creo Parametric 9.0.11.0, Creo Parametric 11.0.5.0 and Creo Parametric 12.4.1.0.
