PDF Print Name
AlanN
PDF Print Name
Whenever I print to PDF, instead of the file name coming out as the drawing name i instead get
the prefix Creo Parametric - (character that looks like a chessboard), then the file name, then four additional digits.
This is not just Adobe, but with other pdf print options too.
So each time I save I have to delete this extra detail. which is really annoying and time consuming.
But if I save as PDF it screws with text and line thickness.
I can't find where it is pulling this additional detail from, or how to stop it.
Thanks in advance if you can help!
4 REPLIES 4
MartinHanak
(To:AlanN)
just some tips for Save As PDF operation. Your config.pro file must contain following options:
use_8_plotter_pens yes
pen_table_file E:\users\creo7_parametric\pentable.pnt
pdf_use_pentable YES
If you have additional question the simply ask it.
Martin Hanák
AlanN
(To:MartinHanak)
Thanks Martin
Yes, this was already set as this.
Any ideas on the PDF naming issue I am having?
MartinHanak
(To:AlanN)
@AlanN wrote:
Thanks Martin
I do not use PDF printer to create PDF file representing Creo drawing. I can only provide some advices related saving PDF directly from Creo.
Martin Hanák
Catalina
Moderator
(To:AlanN)
Hi @AlanN ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
