Parameter with value of the mass by MODELCHECK
ND_10940562
11-Garnet
Hello
Using creo 8
I've been trying so hard to create a parameter with the value of mass but nothings has worked for me
would love some help
my check file its set like this;
MODEL_NAME_STR YN Y N N N N
ADD_CHK_PARAM YN Y N N N N
STARTCHECK YNEW E E E E E
GEOM_CHECKS YNEW Y N N N N
PARAMCHECK YNEW W N N N N
STARTPARM YNEW W N N N N
PRT_DENSITY YNEW E N N N N
DEF_DENSITY YNEW Y N N N N
MATERIAL_DENSITY YNEW Y N N N N
ACCURACY_INFO YNEW Y N N N N
my start file:
PRT_ADD_CHK_PARAM PRT_NOME MODEL_NAME_STR
ASM_ADD_CHK_PARAM ASM_NOME MODEL_NAME_STR
ASM_ADD_CHK_PARAM Massa_Prompmass_add pro_mp_mass
ASM_ADD_CHK_PARAM Massa_mpmass_add mp_mass("")
ASM_PARAMETER Massa_prompmass_parameter REAL EQ pro_mp_mass
ASM_RELATION Massa_Prompmass_relation = pro_mp_mass
ASM_RELATION Massa_mpmass_relation = mp_mass("")
ive enalble calculating the mass automatic in config.pro
4 REPLIES 4
Hi @ND_10940562,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Van_AG
(To:ND_10940562)
It seems this is enough in the start file
PRT_ADD_CHK_PARAM mass
PRT_RELATION mass = pro_mp_mass
ASM_ADD_CHK_PARAM mass
ASM_RELATION mass = pro_mp_mass
and better to operate mass-inertial characteristics in the post regen relations
but you can't edit post reg relations by ModelCHECK
I am using Creo 9.x
The syntax as per help documentation is as follows:
Parameters to be added to a model can be specified. Use the following format in the start configuration file to list the parameters to add to the model:
[MODE]_ADD_CHK_PARAM [parameter] [check_output]
where
[MODE] is PRT, ASM, or DRW.
[parameter] is the name of the parameter to be created.
[check_output] is the name of the check whose output is to be used.
For example,
PRT_ADD_CHK_PARAM MATERIAL MATERIAL_INFO
PRT_ADD_CHK_PARAM UNITS_LENGTH UNITS_LENGTH
PRT_ADD_CHK_PARAM MODEL_NAME 0MODEL_NAME_STR
Thus for part...
PRT_ADD_CHK_PARAM mass pro_mp_mass
One would create a separate parameter for mass only when one would like to keep the default units to MMKS but would like to have the mass reported in grams or in tons. In which case, one must create a parameter in the model and set it to the desired units say g / tons / lbs etc.
Regards
Srinivasan Iyer
Hello @ND_10940562
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
