@Sarvesh_B wrote:
Hi @PaulHeatheringt,
You can refer to the article CS398358 this might help you to resolve the issue.
I applied solution mentioned in https://www.ptc.com/en/support/article/CS398358 and it resolved the problem.
Can you call your VAR (Value Added Reseller)?
They should be able to walk you through the set-up process.
Or open a tech support ticket if you aren't thru a VAR. https://www.ptc.com/en/support
Are you a new Creo user or coming from an older version?
Do the workstations have a PTC certified configuration?
Try renaming any configuration files so they don't load.
Try setting the following in your config.pro to use the built-in graphics: graphics win_gdi
Paul,
We typically see crash on startup with new versions when the graphics card isn't OpenGL certified, is too old, the graphics drivers are old, and/or the graphics drivers are not configured properly for running Creo Parametric.
As Ben suggested, try starting Creo Parametric with the config.pro option graphics win_gdi.
From the PTC KB:
Dan N.
Is a trail file and/or traceback file generated? If so, can you attach them here?
