Traceback error when exporting as .pvz
himungan
6-Contributor
I have a problem about exporting my model into .pvz file. However when i attempt to export, they got an error that generates traceback.log file.
You can see some attempts that i tried;
- Updating graphic card driver
- Assigning a parameter which enable_opengl_fbo no
7 REPLIES 7
Our Support Assistant should not have suggested to publish your question related to Traceback on the Community. It is likely to be a technical glitch that we need to fix on our end. We will open a case for you.
I hope that this experience will not discourage you from future participation in the Community.
Andra
himungan
6-Contributor
(To:achirila)
Did you open the case? It is critical issue for us.
Thank you
StephenW
(To:himungan)
Community moderators don't open tech support cases.
You need go to https://www.ptc.com/en/support and create a tech support case
OR
If you are thru a VAR, you will need to contact them for tech support.
himungan
6-Contributor
(To:StephenW)
esupport does not allow me to open case for creo 6.
StephenW
(To:himungan)
Does this issue happen on ALL exports to PVZ or just on the specific model you are trying to export? If its only the one specific model, it's possibly a data specific problem that would be difficult. If it is all exports, then it is possibly a setting.
You can try temporarily removing all your config.pro/config.sup, customization files and restart creo and test if that works. If so, then its a local setting you have.
With a little more info, maybe someone on here can help further
BenLoosli
(To:himungan)
How are you trying to export a model to a .pvz file? Those files are ProductViewZipped files and usually generated by Creo View Adaptors now.
himungan
6-Contributor
(To:BenLoosli)
File --> Save As -- > Save a copy --> Creo View (.pvz)
