Printer select by Paper Size
Jose_Costa
I think this is possible, but I don´t know how to do it:
We have a plotter and a printer(Okic5600).
I want to create a mapkey to print with the following condition:
If paper size=A4 send to Printer
Else
Send to Plotter
I´m trying to achieve this with one single click. Can this be done using the PCF files?
I'm also having problems configuring the pcf file for the Oki printer. I made a copy of generic postscript pcf file and added the Plotter Command: WINDOWS_PRINT_MANAGER OkiC5600
It always returns an error message on printer:"Error: Invalid Data"
I tried through DOS commands too (using "print /d", "lpr" and "net use") always getting the same result.
I´m using Creo 2 on Win7 and the printer is directly conected to the network.
Thanks.
Jose,
1.]
In PCF file, you cannot use IF-THEN-ELSE command.
2.]
According to http://www.okic5600.co.uk/index.asp?content=okic5600spec , your printer does not understand Postscript language (see Printer languages section). You have to print using MS Printer Manager from Creo.
Martin Hanak
Martin Hanák
Hi Martin,
Thanks for your help.
I think that I gonna give up of the automatic printer selection for now.
If I can´t use a pcf file to control the printer, I will create a mapkey using the Ms Printer Manager and then call a script to automate the process.
Jose
I come back to this subject using another aproach.
My main target is to have only one mapkey to print/plot drawings.
By now, I have two mapkeys: one that sends a drawing to a printer, and other thats sends to a plotter.
I´m trying to create a third mapkey using a small external script that reads the value of the drawing parameter "$format" then calls the designated mapkey.
This is the only thing that is missing. If it was a normal parameter I could edit it and copy the value to the clipboard and it was done. Now, as it is a system parameter I don´t know how to get it.
Any ideas ?
José
Jose,
you can put plotter_command option, see the following example:
plotter_command CMD /C c:\bin\printfile.bat
In printfile.bat you can do what do you want...
Print file is passed on as 1st argument when printfile.bat is called, therefore you can use %1 inside it.
%1 represents print file, you can analyze its contents and look for drawing size. Then you can send print file to the right printer.
Martin Hanak
Martin Hanák
