Printing to zoom with WF 5...
DarrinHiebert
We have our WF 5 mapkeys set to print based on zoom, since we sometimes zoom in to print.
However, we've found that they do NOT print based on zoom, the FIRST time that you execute the mapkey. But, this mapkey works IF you're on the Publish tab to begin with.
What's happening is that every time that you hit the Publish tab, WHEN YOU'RE ON A DIFFERENT TAB, Pro automatically does a zoom all (or default) for you, even if you don't want it. So, if you're zoomed in, it zooms back out to default, and then prints. Then, you zoom in, and hit print again, and it will stay based on zoom, because the Publish tab is already active.
Is there someway to prevent Pro from doing the auto-zoom when switching to the Publish tab? I searched the configs for print and plot, and neither seem to offer any insight into a config option that might prevent this from happening.
Has anyone else experienced or noticed this, and is there a workaround that you're employing to keep it from doing this?
0 REPLIES 0
